RSS discussions
Discussion Discussion forum
Topic ClosedOLE not plotting
 Post Reply Post Reply
Author
onlysee2d View Drop Down
Newbie
Newbie
Using: Autocad 2004
Status: Offline
Direct Link To This Post Topic: OLE not plotting
    Posted: 20.Aug.2013 at 16:24
I've copy and pasted an excel (office 2003) page into an autocad 2004 drawing, as well as 'inserted' it as an OLE....either way, I can get it to print on my local printer, but not on a (2 different) network printer...it prints the drawing, just not the OLE....I cannot find any printer specific settings that would effect the contents of what's being printed...I'm sure it's something ridiculous....any ideas?
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 20.Aug.2013 at 16:26
And what happens if you print directly from Excel?  Does the spreadsheet print?
Edited by John Connor - 20.Aug.2013 at 16:27
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: Autocad 2004
Status: Offline
Direct Link To This Post Posted: 20.Aug.2013 at 16:44
Yes it will print from excel just fine, whether I print the original or the embedded page (opened from CAD)...I'm trying to figure out the difference between inserting an OLE and just copying and pasting from excel into cad....is there any difference? It shows up on the print preview....it's like it's 'white' and thinks it's printing it...I tried selecting it and changing the color but no change...
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 20.Aug.2013 at 18:50
That's one of the reasons I avoid using OLE objects.  Unfortunately your version of AutoCAD is too old to have the Table > DataLink feature that came along in 2008.
Is your table in model space or in paper space?
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: Autocad 2004
Status: Offline
Direct Link To This Post Posted: 20.Aug.2013 at 18:53
Model space....Ya, I was looking for some 3rd party s/w and the one I found didn't work either (AutoTable)..at least I couldn't get the trial to work...
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 20.Aug.2013 at 19:45
Try inserting it is paper space instead.
I too tried AutoTable at one point but it did not do what I needed.  Did you look at the Readme file that came with the trial version?
<<AutoCAD 2015>>
Back to Top
ahmad.muammar View Drop Down
Newbie
Newbie
Using: autocad2013
Status: Offline
Direct Link To This Post Posted: 21.Aug.2013 at 15:14
I think there's way for resolve that by going to menu -> then edit -> then select paste special  -> then you have to select AutoCAD entries  before doing above steps you should go to excel sheet and make copy from your work
Back to Top
heinsite View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 22.Aug.2013 at 11:09
You say you can get it to print correctly to a local printer... can you get it to print equally well as a DWF?  If so, from there you should be able to print it properly to any other printer or plotter.
Dave.
Dave Hein, P.E.
Hawaii District Engineer
Kona International Airport
AutoCAD Certified Professional
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,085 seconds.
