RSS discussions
Discussion Discussion forum
Topic Closedusing PROJECTGEOMETRY
 Post Reply Post Reply
Author
ist4000 View Drop Down
Newbie
Newbie
Using: AutoCAD2013 Mac
Status: Offline
Direct Link To This Post Topic: using PROJECTGEOMETRY
    Posted: 01.Sep.2013 at 22:20
Hello!
I'm trying to "draw" a logo from AI on a AutoCAD "wall". And I have some problems about it.
The dwg export from the Illustrator is a hatch. The wall in AutoCAD is a 3D solid. So I try PROJECTGEOMETRY. Since it works only with lines and polylines I "recreate boundary" in the hatch edit, get splines, in order to get polylines I try a lisp from the web which doesn't work, I do it manually to finally use PROJECTGEOMETRY.
It doest't work.
So I created a planar surface and a simple line to test. It didn't work neither. What might be wrong and how to do it right?
Thanks
Back to Top
Vladimir Michl View Drop Down
Senior Member
Senior Member
Using: Autodesk software
Status: Offline
Direct Link To This Post Posted: 01.Sep.2013 at 22:28
Try to explode the imported geometry to simple entities. Is the 3D object really a surface?
See also:
Vladimir Michl
//CADs.cz, LinkedIn
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 02.Sep.2013 at 01:13
Thanks. The link have already been my first choice to learn about draping. But:
I open a new drawing, I draw a plansurf, I draw a line, I want to project the line on the planar surface, I choose the line, enter, I coose the surface, enter, enter.
Command: PROJECTGEOMETRY
SurfaceAutoTrim = 0
Select curves, points to be projected or [PROjection direction]: 1 found
Select a solid, surface, or region for the target of the projection:
Specify the projection direction [View/Ucs/Points] <View>:
0 object(s) projected successfully.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,188 seconds.
