RSS discussions
Discussion Discussion forum
Topic ClosedMeasure command error
 Post Reply Post Reply
Author
bdeckman View Drop Down
Newbie
Newbie
Using: Revit, autocad
Status: Offline
Direct Link To This Post Topic: Measure command error
    Posted: 04.Dec.2013 at 20:04
We are having an issue on one of our PC's where the operator attempts to use the measure command and start from a point but the command "jumps" and gives the wrong point in the measurement. I hate doing a reinstall, we just did one about a month ago. Any ideas?
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 05.Dec.2013 at 00:01
Your first choice of action should never be uninstalling/reinstalling AutoCAD.  That would be like swapping out the gas tank on your car because you ran out of gas.
Maybe it's jumping because the operator has SNAP enabled.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 05.Dec.2013 at 14:03
I was also thinking maybe it had to do with not being in model space. I will check both of those today.
Back to Top
LouLou7 View Drop Down
Newbie
Newbie
Using: Auto Cad 2009 Lt
Status: Offline
Direct Link To This Post Posted: 05.Dec.2013 at 16:13
It's the Snap settings, untick the snap settings and then you will have no problems, sometimes it does tick this, without knowing, the comand can be quite frustrating.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 05.Dec.2013 at 16:54
SNAP can be enabled merely by accidentally hitting the F9 key with your fingers.  Any other way it is enabled would be deliberate unless you were using a custom lisp routine that required SNAP to be enabled and when finished it failed to disable the command.  This is bad form as far as lisp gurus are concerned.
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,227 seconds.
