RSS discussions
Discussion Discussion forum
Topic Closedscaling problem
 Post Reply Post Reply Page  <12
Author
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 16.Apr.2015 at 13:09
uploads/175428/FOR_CAD_FORUMPJH.dwg
Hello akoarkitekto, you have mainly 2 problems on your file :
The drawing on the right has beem scaled by 2.5 and the dimension style STANDARD$0 for linear dimensions has been modified with a scale factor of 0.4 to cope this ( x2.5 = 0.4).
It's better to work at scale 1/1 and open viewports in the paper space to have different paper scales.
The drawing on the left is OK ( drawn in meters , dimension style STANDARD$0 is working ).
You can work with different units in different files or insert ( and not copy/paste ) different units files inside the first one but you have to set UNITS with the good value in the diffrent files.
Edited by philippe JOSEPH - 16.Apr.2015 at 14:07
Back to Top
akoarkitekto View Drop Down
Newbie
Newbie
Using: AutoCAD2013,AutoCAD2010
Status: Offline
Direct Link To This Post Posted: 16.Apr.2015 at 12:13
Please see attached file..
this is the sample cad file that i am working with..
1.Another question is.. the elevation in the drawing said that is scaled in 1:50mts. But when i draw a line with the same measurement like 5.000 mts and compare it with the drawing.. it's  the same but when i measured its dimension it gives me the wrong dimension..
2. How can i scale the elevation into 1:20 mts like in section details... or is that i draw it first in 1:100 mts and then just scale/resize it bigger to <scale><reference>2.?
Thanks.
CAD FILE:
uploads/552290/FOR_CAD_FORUM.dwg
Thanks..
AKOARKITEKTO
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 16.Apr.2015 at 11:53
It sounds like you have a mixed units problem.  You reference a scale factor of 1:50 (metric) yet your paper size is stated in imperial units (20"x30").  Never a good idea to mix metric and imperial.
Attach a copy of the drawing to your next post or upload it to the CAD Blocks section of this website.  Images aren't useful at this point; we need a DWG file.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 16.Apr.2015 at 03:35
.......or just it the secret is in dimstyle? or dimscale?...
Thanks..
AKOARKITEKTO
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 16.Apr.2015 at 02:55
Thanks..
AKOARKITEKTO
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 16.Apr.2015 at 02:46
no i am working in "model" and  i have a 20"x30" template or A1 size paper..
In "layout" i paste the template and put one viewport and zoom it with 1/5xp and drawing is still small...
Thanks..
AKOARKITEKTO
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 15.Apr.2015 at 12:24
Please confirm you are in a paper space layout using at least one viewport.  Yes/No/Not sure?
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 15.Apr.2015 at 09:59
Good day.. I"m having a hard time in get the correct scale.. or to scale the drawing from 1:100 mts to 1:50 mts. Comparing the two drawing, 1:50 is much larger than 1:100 mts. I tried to scale my drawing which is in 1:100 with the reference scale factor  "2" and i compare it to the 1:50 dwg but it did match...TIA
I hope you can help me guys.. thanks a lot.
Thanks..
AKOARKITEKTO
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,088 seconds.
