RSS discussions
Discussion Discussion forum
Topic ClosedSweep command problem
 Post Reply Post Reply
Author
4riders View Drop Down
Newbie
Newbie
Using: autocad 2013
Status: Offline
Direct Link To This Post Topic: Sweep command problem
    Posted: 18.Jan.2016 at 08:09
Hello,
i try to  do sweep command. i have used with no problems until now.
When i used sweep command it was sweeping this shape into a solid.
Now, when i sweep it converts it into a surface.
Do you have a solution to sweep this shape into a solid and not in a surface ?
uploads/526420/dormitor_lupu.dwg
Back to Top
Newbie
Newbie
Using: autocad 2013
Status: Offline
Direct Link To This Post Posted: 18.Jan.2016 at 08:58
i tryed sweep command with surface mode 1 - 0 but it creates surface or nurbs surfaces.
i tryed extrude command with solid mode on but it says :
path curve is coplanar with or tangent to the plane of the profile curve
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 18.Jan.2016 at 12:27
You must be doing something wrong then.  The key line in the error message is the last one that starts "curve path is coplanar...."  You'll have to try again.
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 18.Jan.2016 at 12:58
Hello 4riders and John, I have open your file and found :
5 Solids OK , 6 closed polylines OK for the command : EXTRUDE and 2 non coplanar lines.
Please let us know on which entity you have a problem.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,148 seconds.
