RSS discussions
Discussion Discussion forum
Topic ClosedPasting Problems
 Post Reply Post Reply
Author
benny View Drop Down
Newbie
Newbie
Using: autocad 2011
Status: Offline
Direct Link To This Post Topic: Pasting Problems
    Posted: 13.Oct.2008 at 05:56
Hi everyone i was just wondering if anyone could help me. I am trying to copy and paste with base point from one drawing to another but it doesnt work it keeps coming up with '_pasteclip' and does nothing, i have no idea what is wrong tryed everything can think of this has never happened to me before. hopefully some one can help cause it is really annoying.
thanks everyone.
Back to Top
PepaR View Drop Down
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 13.Oct.2008 at 08:18
Check keyboard shortcust in CUI.
If you are using AutoCAD 2007, apply last service pack and updates, please.
Back to Top
Vladimir Michl View Drop Down
Moderator Group
Moderator Group
Using: Autodesk software
Status: Offline
Direct Link To This Post Posted: 13.Oct.2008 at 16:16
Vladimir Michl (moderator)
Back to Top
Kajito View Drop Down
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 29.Oct.2008 at 18:20
well, I guess this should be easy solution:
I've had this kind of problems thro the office many times and one of following 4 solutions always helped:
1) "purge" or "-purge/all"?
2) drawing audit
3) open close autocad
4) rename block. There might be block with the same reference/name so it will not let you to copy it
hopefuly it will help in future :)
Back to Top
spacedecor View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 30.Oct.2008 at 07:44
Do you check your current layer or past object layer on/off ?
Back to Top
AllieEatsSushi View Drop Down
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 31.Oct.2008 at 18:29
This same problem has happened to me before. Try zoom extents after you have pasted into your new drawing. Perhaps the scales are different, and what you pasted is just out of your sight.
Hope this helps.
-Allie
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,244 seconds.
