RSS discussions
Discussion Discussion forum
Topic Closedprinting scaling problem
 Post Reply Post Reply
Author
swedencad View Drop Down
Newbie
Newbie
Using: autocad2016
Status: Offline
Direct Link To This Post Topic: printing scaling problem
    Posted: 28.Apr.2017 at 08:38
Hello,
I have a HP Designjet T770 44 inch printer.
I have a A0 template for my drawings.
When i print i use scale to fit paper and i use A0 paper 841mm format like in the link below:
I think it is just standard A0 papper but when i print the drawing is not scaled well. it looks like the drawing is made smaller becaude of the paper. Do i need bigger paper?
My printer can print maximum on 1118mm width.
Sorry i am just a new autocad user.
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 28.Apr.2017 at 11:25
Hello swedencad, it looks like your paper width is 841 mm ( approx. 33 inches ) so if you launch a A0 ( 841 mm width ) to be printed it will be printed smaller because the printer doesn't print without margins.
Eventually you could see if you can buy ( and install on your printer ) paper width 914 mm ( approx. 36 inches ).
Then when you print a A0 ( length 1189 x width 841 ) it is at scale 1/1 and you eventually have to cut some millimetres around the format.
Edited by philippe JOSEPH - 28.Apr.2017 at 11:27
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 28.Apr.2017 at 12:05
If you wanted to print your drawing "to scale" why would you use the "Scale to Fit" option?  That makes no sense.
Are you printing from model space or from a layout?
Is there a title block and border?
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,146 seconds.
