RSS discussions
Discussion Discussion forum
Topic ClosedHELP 3D
 Post Reply Post Reply Page  <12
Author
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 11.Aug.2017 at 16:52
Honestly, you don't want to use the Fillet command.  I think you would be better off making use of a mesh object that you can alter the vertices as needed to attain the shape you are looking for.
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 11.Aug.2017 at 18:22
I have another idea.  Maybe you can extrude two different shapes (the cloud being one), as solids, not surfaces, then run the INTERFERE command on them but do NOT delete the object that is created via the intersection of the two solids.
Edited by John Connor - 11.Aug.2017 at 18:22
<<AutoCAD 2015>>
Back to Top
scj.schulz View Drop Down
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 12.Aug.2017 at 22:47
Hallo again,
see the attachement (marked up area) - I suppose I found the reason, why you cannot use FILLETEDGE wit a RADIUS greater than 10.8 - you'll get into geometrical problems.
Or you should try to find out non-circular-arc-based FILLET...
(Perhaps you could create a special filleting-tool for this - see the attachement in my first answer).
Regards
Jochen
www.ant-ares.deuploads/87494/Cloud-1.dwg
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 14.Aug.2017 at 11:33
Fillet is not going to solve the problem in its entirety.
Edited by John Connor - 14.Aug.2017 at 12:10
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,172 seconds.
