RSS discussions
Discussion Discussion forum
Topic ClosedJoin AutoCAD line
 Post Reply Post Reply Page  12>
Author
mudassar_javed View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Topic: Join AutoCAD line
    Posted: 29.Sep.2017 at 06:15
I want to   join end point of these two line with out changing the length of these two lines. please help which command is used...
Edited by mudassar_javed - 29.Sep.2017 at 06:17
Mudassar
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 29.Sep.2017 at 08:10
 Hello Mudassar, if I understand you want to "move" the two lines without changing their length to the " projected intersection" of them.
Then if yes use the command MOVE from one end of one line to the PROJECTED INTERSECTION of the 2 lines.
You have the option PROJECTED INTERSECTION ( if correct because my AutoCAD is in French ) with Ctrl+right clic.
Back to Top
Kent Cooper View Drop Down
Senior Member
Senior Member
Using: AutoCAD2020, 2023
Status: Offline
Direct Link To This Post Posted: 29.Sep.2017 at 17:09
In English versions that's called the APPARENT INTERSECTION.
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 01.Oct.2017 at 05:19
Thanks for you reply. Let me clarify the question. Please see picture below
Edited by mudassar_javed - 01.Oct.2017 at 09:54
Mudassar
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 01.Oct.2017 at 13:10
Rotate the line on the left to meet up with the line on the right.  Use the endpoint circled in red of the left line as the base point for the rotation.  I assume you are smart enough to figure out the angle of rotation.
Edited by John Connor - 01.Oct.2017 at 13:11
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 01.Oct.2017 at 13:14
Hello mudassar_javed, you will have to draw centered circles at the extremities of the lines in the red circles.
Then you get the intersection to keep the 2 lines lengthes unchanged.
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 03.Oct.2017 at 08:39
Thanks Philippe JOSEPH
I am unable to do. Can u please demonstrate it.
Mudassar
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 03.Oct.2017 at 11:34
You could have written the next great Pakistani novel by now.
I think this is what you were told to do.
The intersection of the two circles (circled in red) is where the two lines should meet.  By clicking on the green line and checking Properties you'll find the angle of the line.  Invoke the Rotate command and select the line.  Next, select the basepoint.  When prompted to specify the rotation angle note that there are two other available options - Copy and Reference.  Choose the Reference option.  When asked to specify the Reference angle type in the angle you got from the Properties palette.  When asked to specify the new angle pick the intersection of the two circles.  Done.  All of this takes less than 20 seconds and that includes having a cup of tea.  If you skip the cup of tea it can be done in half that time.  You are making this way more difficult than it needs to be.
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 03.Oct.2017 at 14:16
Yes John and mudassar_javed, or you can have the option of just clicking the lines and use the end grips "at hand" to connect them at the intersection of the 2 circles ( working with the grips ).
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 03.Oct.2017 at 15:54
Maybe you should have mentioned that to the OP right from the start?
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,125 seconds.
