RSS discussions
Discussion Discussion forum
Topic ClosedProblem with OSNAP
 Post Reply Post Reply
Author
mpinter View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Topic: Problem with OSNAP
    Posted: 11.May.2010 at 12:08
I have a problem with OSNAP.
I have only Intersection Object Snap selected, and my cursor is snapping on every node in the polyline.  It is similar with Endpoint Object Snap. Confused
Any ideas?
Back to Top
zitree View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 17.May.2010 at 07:48
You have only Intersection selected, but have you press F9 button ?
I'm CAD Drafter from Indonesia trying to know everything about CAD
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 17.May.2010 at 08:20
Of course I have.
It does snaps to intersections, the problem is that it also snaps on nodes. Confused
Marko
Back to Top
CarlB View Drop Down
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 17.May.2010 at 09:08
I believe Autocad sees a vertex (not node) in a polyline to be an intersection of 2 segments, so when intersection osnap is active, it snaps to a vertex along with other intersections.
"node" is a different snap mode, which snaps to points.
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 17.May.2010 at 20:28
OK, that sounds reasonable.  But is there any cure for that problem?
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 18.May.2010 at 02:48
Only cure I know of is to to enable osnaps (hit F3) only when your cursor is over the intersection point you want to use.
Back to Top
nameci View Drop Down
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 18.May.2010 at 04:38
Hi mpinter,
This may be a stupid question but, have you gone into snap settings and turned off the node setting??
nameci
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 18.May.2010 at 08:19
Of course.
It seems that problem appears when one polyline intersecting the other has very dense vertices.  Then it is really very hard to snap on the point of intersection.  It seems that this is some kind of bug of Autocad.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,113 seconds.
