RSS discussions
Discussion Discussion forum
Topic Closedproblem in drowing
 Post Reply Post Reply Page  12>
Author
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Topic: problem in drowing
    Posted: 19.Nov.2014 at 20:03
Looks like esfahan gave up.  Too bad.
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 17.Nov.2014 at 11:31
That would be another way to do it.  Not sure if the OP knows what constraints are or how to apply them.
<<AutoCAD 2015>>
Back to Top
sourcecad View Drop Down
Newbie
Newbie
Using: AutoCAD, CATIA, Revit
Status: Offline
Direct Link To This Post Posted: 17.Nov.2014 at 09:43
Constrain length of both the lines using parametric tool of AutoCAD and then connect line ends using grip editing.
Admin thesourcecad.com
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 16.Nov.2014 at 18:42
sourcecad: The OP states the angle is not important but the distances are.  Your solution using the Fillet command would make each line longer.  Note too the OP has not provided an angle for the line that is 6.4 so depending on what the angle might be the final length using Fillet could, at this point, vary widely.
Edited by John Connor - 16.Nov.2014 at 18:46
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 16.Nov.2014 at 13:40
I hope this image makes things clear
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 16.Nov.2014 at 13:02
Really?
The red circle has a radius of 6.4 and the cyan circle has a radius of 4.8.  You said you did not care about the angle of the lines so there you go.  The red and cyan lines are the lengths you specified.
<<AutoCAD 2015>>
Back to Top
esfahan2000 View Drop Down
Newbie
Newbie
Using: cad 2014
Status: Offline
Direct Link To This Post Posted: 16.Nov.2014 at 07:39
Originally posted by John Connor John Connor wrote:
You could draw two circles using 6.4 and 4.8 as the radii.  Where they cross will be the location of the upper right corner of the object.
I'm assuming you know where to locate the centerpoint of each circle.  Yes?
could you explain more?
Back to Top
Newbie
Newbie
Using: cad 2014
Status: Offline
Direct Link To This Post Posted: 16.Nov.2014 at 07:38
Originally posted by sourcecad sourcecad wrote:
the best and easy method is to follow the steps
Go to fillet command > click on radius on command line or type R and enter > enter a radius of 0 > click on end points of both lines.
the lines will get connected at their apparent point of intersection, Hope it helps  Tongue
it chang's the length
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 16.Nov.2014 at 06:36
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 15.Nov.2014 at 18:28
Edited by John Connor - 15.Nov.2014 at 21:13
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,069 seconds.
