RSS discussions
Discussion Discussion forum
Topic Closedshortcut draworder
 Post Reply Post Reply
Author
roel-nahuis View Drop Down
Newbie
Newbie
Using: AutoCAD2019
Status: Offline
Direct Link To This Post Topic: shortcut draworder
    Posted: 20.Jun.2019 at 08:12
hello,
is there an shortcut for draworder send to back and bring to front?
Back to Top
rebellio View Drop Down
Senior Member
Senior Member
Using: Autocad 2018
Status: Offline
Direct Link To This Post Posted: 20.Jun.2019 at 10:14
Hi,
Shortcut is "DR"
Adjustable via "Aliasedit" if preferred.
Regards
Edited by rebellio - 20.Jun.2019 at 12:44
Back to Top
Newbie
Newbie
Using: AutoCAD2019
Status: Offline
Direct Link To This Post Posted: 20.Jun.2019 at 10:24
Thanks, it works!!!
Back to Top
Kent Cooper View Drop Down
Senior Member
Senior Member
Using: AutoCAD2020, 2023
Status: Offline
Direct Link To This Post Posted: 20.Jun.2019 at 14:44
Originally posted by roel-nahuis roel-nahuis wrote:
... is there an shortcut for draworder send to back and bring to front?
I use two little shortcut commands for not just the DRAWORDER command [which still requires you to specify Back or Front], but for the command with the Back or Front option included in the command operation, without your needing to answer for it [EDIT: just replaced with upgraded version that allows pre-selection]:
;;  DraworderBackFront.lsp [command names: DB & DF]
;;  To put selected objects at the Back or Front of the Draworder
;;  Kent Cooper, last edited 20 June 2019 [work with pre-selection]
(defun DBF (which / cmde ss)
  (setq cmde (getvar 'cmdecho))
  (if (ssget "_I")
    (setq ss (ssget "_I")); then
    (progn ; else
      (prompt (strcat "\nTo move to " which " in draw order,"))
      (setq ss (ssget ":L"))
    ); progn
  ); if
  (if ss
    (progn ; then
      (setvar 'cmdecho 0)
      (sssetfirst nil nil); clear if via pre-selection
      (command "_.draworder" ss "" (strcat "_" which) "_.regen")
      (setvar 'cmdecho cmde)
    ); progn
    (prompt "\nNothing selected."); else
  ); if
  (princ)
(defun C:DB ()
  (DBF "Back")
(defun C:DF ()
  (DBF "Front")
Edited by Kent Cooper - 20.Jun.2019 at 15:04
Back to Top
Vladimir Michl View Drop Down
Moderator Group
Moderator Group
Arkance Systems CZ
Using: Autodesk software
Status: Offline
Direct Link To This Post Posted: 21.Jun.2019 at 07:28
There is also a menu macro predefined in CUI - you can assign any keyboard shortcut to it to invoke it faster than through the ribbon.
Vladimir Michl (moderator)
ARKANCE - https://arkance.world - Autodesk Platinum Partner
Back to Top
Senior Member
Senior Member
Using: Autocad 2018
Status: Offline
Direct Link To This Post Posted: 21.Jun.2019 at 15:54
"Borrowed" this one from you Kent, thanks for sharing Wink
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,295 seconds.
