RSS discussions
Discussion Discussion forum
Topic Closedview port boundries
 Post Reply Post Reply Page  <12
Author
heinsite View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 27.Jan.2012 at 20:20
Originally posted by designbo designbo wrote:
Great!! works, now one question,, can I change the view port from the retangle to the poly without having to replace existing view port???
I didn't actually try this but it seems it should work also...
Since a rectangle is also a polyline you should be able to use PEDIT (or a right click option) to add a vertex or two where ever you like to the existing viewport, and drag and drop them as needed.  Done.  No real need to make a new viewport, delete the old one, etc.  The main thing is to use which ever method is faster or more understandable to you.  AutoCAD provides lots of ways to clean the same cat.
Dave
Dave Hein, P.E.
Hawaii District Engineer
Kona International Airport
AutoCAD Certified Professional
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 27.Jan.2012 at 21:36
The OP may be using the existing viewport as a reference.
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 27.Jan.2012 at 21:43
Even if he is using it as a reference he originally asked how to change its shape.  At this point we've offered several ways of doing it, so the ball is pretty much in his court to come back and let us know how he made out.
I'm going to have to try my own suggestion here shortly... right after I get done with a rebuild.  I'm still plagued with that Windows Update mess from the other day.
Dave.
Dave Hein, P.E.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 28.Jan.2012 at 07:29
I should have tested things *before* posting earlier because one can not edit the viewport boundary as if it were a polyline.  My bad.  My version of AutoCAD was also on the fritz at the time too.
Cry
Dave.
Dave Hein, P.E.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 28.Jan.2012 at 12:23
Well it was worth a try right?
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 29.Jan.2012 at 05:33
Yeah.  And it seemed so logical at the time.  Embarrassed
Dave.
Dave Hein, P.E.
Back to Top
designbo View Drop Down
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 30.Jan.2012 at 15:26
will try that and see if it works..
thanks will let you know..
been tremendous help..
andsly
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 30.Jan.2012 at 15:33
worked!!!! thanks for the information...
andsly
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,102 seconds.
