RSS discussions
Discussion Discussion forum
Topic Closedacad2000
 Post Reply Post Reply Page  12>
Author
trautman View Drop Down
Newbie
Newbie
Using: acad14,acad2000,acad2006lt, draftsight
Status: Offline
Direct Link To This Post Topic: acad2000
    Posted: 08.Apr.2014 at 01:25
Help! ive turned something off, when, i window an object to move or copy i lose the item when i need to pan dyn HELP!!!! thanx
it aint rocket science
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 08.Apr.2014 at 11:30
Check the setting of both PICKFIRST and while you are at it PICKADD as well.  They should both be set to "1".
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 08.Apr.2014 at 12:58
THANX. I tried both ways, 0 and 1 on both oickfirst and pickadd to no av-ale. thanx for your help. mike
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 08.Apr.2014 at 14:23
PICKADD and PICKFIRST should always be set to a value of 1.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 08.Apr.2014 at 21:36
John thanx for the input. i have both set to 1 the problem persist. i hope im clear about the situation?
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 11.Apr.2014 at 23:49
I need help on this one!!! I may have to pay for an answer!!!!
Thanx All
tfhmrt@gmail.com
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 15.Apr.2014 at 21:33
What program are we actually talking about?
What else have you tried thus far?  No sense suggesting things you have already tried.
Have you tried a REPAIR of the installation?
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 15.Apr.2014 at 22:38
John thanx for the reply,
the program im using is (autodesk autocad 2000)No i have not tried (repair), How does that work. im one of thoes " if it does not work i call my IT guy. he knows nothing about this program! i have used acad for years starting with R14,acad2000, acad 2006 lt,now Draftsight. Im not to smart when it does not work!!
thanx Mike (tfhmrt@gmail.com)
Back to Top
Robert_D View Drop Down
Senior Member
Senior Member
Using: BricsCAD v25, AutoCAD2006
Status: Offline
Direct Link To This Post Posted: 15.Apr.2014 at 23:32
Originally posted by trautman trautman wrote:
... (autodesk autocad 2000)No i have not tried (repair), How does that work...
Been a while since I've used v2000, but assuming little has changed: Reinstall or Repair AutoCAD: http://docs.autodesk.com/ACD/2011/ENU/filesInstall/WS1a9193826455f5ff3d6161141208a8044f3-79e5.htm
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 16.Apr.2014 at 11:48
The REPAIR option will require that you have the original installation media.  Do you still have the CD?
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,301 seconds.
