RSS discussions
Discussion Discussion forum
Topic ClosedRegarding constraing bar
 Post Reply Post Reply
Author
sachinbansude View Drop Down
Newbie
Newbie
Using: AutoCAD2013
Status: Offline
Direct Link To This Post Topic: Regarding constraing bar
    Posted: 01.Aug.2014 at 12:17
Hi,
I am working on cabinet design & if I copy some items (item graphic) & pasting somewhere else it is showing so many constraing bars, now if I want to dele all the constraint bars at a time, so how to do that or how I can remove that constraint bars.
Please find attached snap shot for reference & provide the solution
Regards,
Sachin Bansude
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 01.Aug.2014 at 12:42
To delete the constraints go to your Parametric tab and look on the Manage panel for the Delete Constraints command.
To disable constraints altogether look on the task bar at the bottom left hand corner of your screen and click on the first icon.  I believe that it is labeled Infer Constraints.  It is either enabled or disabled.
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,201 seconds.
