RSS discussions
Discussion Discussion forum
Topic ClosedDimension text size
 Post Reply Post Reply
Author
LeeP View Drop Down
Newbie
Newbie
Using: AutoCAD 2010
Status: Offline
Direct Link To This Post Topic: Dimension text size
    Posted: 29.Apr.2015 at 11:33
AutoCAD 2012
I've created a dimension style which is fine, except for the fact that the text, although the correct size is drawn in a wider line width, so it looks bold. The only way I can alter it is after a dimension is inserted in the drawing and then I change the line width from 0.30 to 0.09
The text style for the dimension is a style used in the drawing where it displays correctly.
Why will the text not display correctly in dimensions - what am I missing?
Thanks,
Lee
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 29.Apr.2015 at 11:38
There is noting in the dimension style dialog box pertaining to lineweight.  Are you sure you specified the correct Text Style?
Are your dimensions on a layer that has a lineweight assigned to it?
<<AutoCAD 2015>>
Back to Top
LeeP View Drop Down
Newbie
Newbie
Using: AutoCAD 2010
Status: Offline
Direct Link To This Post Posted: 29.Apr.2015 at 11:57
Thanks for quick response.
Yes I'm sure the text style is correct...
Your second observation was correct... the current line width on the drawing is set to 0.30 but of course when I select an existing dimension it's set at 0.09  I've now set the layer line width to 0.09 and new dimensions show correctly.
Dumb question as it turns out, but really appreciate your help.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,109 seconds.
