Over 1.132.000 registered users (EN+CZ).
Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
micallen
Newbie
Joined: 14.May.2015 Location: United States Using: ACAD 2011, SW 2015 Status: Offline Points: 12 |
Topic: Acad 2011 - won't print landscapePosted: 10.Nov.2015 at 18:57 |
I remember having this problem about 10 years ago, and don't remember how I fixed it then. Up until recently I had no printing issues. Now, when I try to print to either printer, it ir rotated 90 degrees and too small. It is printing Portrait on a Landscape title block.
I haven't changed anything to my knowledge. When I run Solidworks, it still prints as intended. I have a Samsung ML-2540 laser printer for A size, and an HP Officejet 7110 for B size. I'm running Windows 7. I can't get either to print correctly any more. Any ideas?
__________________
Micallen |
John Connor
Senior Member
Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 11.Nov.2015 at 15:16 |
It would help if you uploaded a copy of the drawing so we could test it out ourselves.
<<AutoCAD 2015>> |
micallen
Newbie
Posted: 11.Nov.2015 at 15:36 |
uploads/559948/2934-174.DWG
Now that I think of it, I only have the problem on DWG files that were converted from SW prints. But it use to never be a problem. If I start with one of my ACAD templates, it prints fine.
__________________
Micallen |
John Connor
Senior Member
Posted: 11.Nov.2015 at 17:04 |
I think you just weren't paying attention to what you were doing.
I downloaded and opened your drawing. I started the Plot command and in the plot dialog box I changed the orientation from Portrait to Landscape. I picked my printer, checked the Preview and then printed. Came out right the very first time. I don't believe it has anything to do with the fact that it was created in SW. Why is there no separate layers for text and dimensions? Why is almost every entity in your drawing the same color (white)? Why wouldn't you use a "centerline" linetype for the centerlines of the holes in the baseplate? Why are the lines used to show the side view of the baseplate on the FORMAT layer? Edited by John Connor - 11.Nov.2015 at 17:14 |
<<AutoCAD 2015>> |
micallen
Newbie
Posted: 11.Nov.2015 at 17:29 |
No Portrait/Landscape selection available. As far as the other items mentioned, these are quick prints usually used to import into nesting software. Still need the prints though. SW creates all the items you mentioned - that's how it converts. I know they look like crap. My templates do not look like that. Just trying to get the print thing figured out.
Edited by micallen - 11.Nov.2015 at 17:30 |
__________________
Micallen |
micallen
Newbie
Posted: 11.Nov.2015 at 17:34 |
uploads/559948/2934_Fencing_Assy-2.DWG
For comparison, here's a print created with my template (no SW involvement). It prints fine.
__________________
Micallen |
micallen
Newbie
Posted: 11.Nov.2015 at 17:37 |
I just figured out a solution. If I use Page Setup Manager each time before I print, I can select Landscape.
__________________
Micallen |
John Connor
Senior Member
Posted: 11.Nov.2015 at 18:22 |
You forgot to click on the black arrowhead in the lower right hand corner of the plot dialog window to expand the remainder of the window where you would have seen the setting for Orientation.
Edited by John Connor - 11.Nov.2015 at 18:33 |
<<AutoCAD 2015>> |
micallen
Newbie
Posted: 11.Nov.2015 at 18:57 |
Uggh. Damn. Thanks. I use SW all day, every day. ACAD has become second fiddle and some of the simple stuff falls by the wayside.
__________________
Micallen |
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,332 seconds.
Topic Options
John Connor wrote:
