Over 1.096.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator and the updated Barcode generator. New AutoCAD 2026 commands and variables.
RSS discussions
Discussion Discussion forum
Topic ClosedLidar DEM into Civil 3D
 Post Reply Post Reply
Author
edigby View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Topic: Lidar DEM into Civil 3D
    Posted: 04.Oct.2007 at 19:58
Do you need the entire LiDAR file in your design -- or can you cut it down to a smaller area or corridor of interest?
You may want to cut the data down to a size Civil3D can handle using software better suited to working with a large LiDAR data set.
Evan Digby
Softree Technical Systems Inc.
http://www.softree.com
"Engineering an Easier Way"
Back to Top
iDraft View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 21.Sep.2007 at 13:21
well first of all lydar information converts to massive files in cad. the best fix to this is to request a point file from the mapper that did the lydar imaging and then import them to cad and do a quick terrain model.
thats probably the most efficient way. and doesn't create file cad can almost barely handle.
the other way is to import the dem file into terramodel then export it out of terramodel into cad. mind it makes a file cad can barely handle.
Edited by iDraft - 21.Sep.2007 at 13:22
Back to Top
humboldt cad View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 09.Aug.2007 at 22:01
I have recieved some LIDAR information which has been translated into a .dem file which I am having some trouble loading into Civil 3D. Does anyone have any suggestions?
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,164 seconds.
