RSS discussions
Discussion Discussion forum
Topic ClosedChange Units to meters
 Post Reply Post Reply
Author
chetauin View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Topic: Change Units to meters
    Posted: 04.Feb.2008 at 10:59
Hi
I want to change the units from millimeters to metres. How can I do it.
Cheers
Chetu
Back to Top
Vladimir Michl View Drop Down
Senior Member
Senior Member
Using: Autodesk software
Status: Offline
Direct Link To This Post Posted: 04.Feb.2008 at 11:20
AutoCAD drawing units are unitless. You need the physical units only for dimensioning and plotting - there are scale settings for these two tasks.
Otherwise you can scale down your drawing with the SCALE command.
Vladimir Michl
//CADs.cz, LinkedIn
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 04.Feb.2008 at 11:25
I have received a drawing which is in millimeters. But now for my easy working I need to start working in meters. So as you mentioned shall i scale the model ?
Well for plot I don't mind because I might not plot the drawing 1:1 scale.
Back to Top
Arben.Allaraj View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2008
Status: Offline
Direct Link To This Post Posted: 04.Feb.2008 at 12:22
If you want work in meters of course you should scale it with 1000 factor.
Dont forget 1:1 it means 1 unit (meter in drawing) = 1 unit (Meter in your letter).
Ing Arben.Allaraj
http://cad-drafting-corner.blogspot.com
Back to Top
spen1967 View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 12.Feb.2008 at 13:50
Hi,
I have AutoCAD set to millimeters and I regularly receive drawings that have been done on a machines set to meters.
The previous answers are correct, you will need to scale all objects by a thousand. However here's a tip - before doing this ensure all objects are visible and selectable. ie all layers unlocked, unfrozen and on.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,207 seconds.
