Over 1.132.000 registered users (EN+CZ).
Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
Concat
Newbie
Joined: 30.Sep.2010 Location: United Kingdom Using: AutoCAD 2010 Status: Offline Points: 1 |
Topic: AutoCAD block - bollardPosted: 05.Oct.2010 at 16:49 |
Hi
Does anyone have AutoCAD block of "Bollards" in plan and elevation? thanks |
Thanks Concat
CarlB
Senior Member
Joined: 16.Oct.2009 Location: United States Status: Offline Points: 321 |
Posted: 05.Oct.2010 at 22:35 |
There are all sorts of bollards, which is basically a post in the ground. You could use a fence post detail and cut it off 42" or so above the ground.
In plan view use an open or a filled circle, pretty simple.
Depending on purpose, bollard can be 4" to 12" diameter, wood (square in section) or steel (sometimes concrete filled), set 3 feet to 4 feet in the ground, sometimes surrounded in concrete 18" in diameter or so. Extends 3 feet to 4 feet above ground.
If needs to be highly visible, paint "safety yellow".
rob s
Newbie
Joined: 14.Oct.2010 Location: Netherlands Using: AutoCAD 2010 Status: Offline Points: 9 |
Posted: 14.Oct.2010 at 00:49 |
I agree with Carl. There are lots of types of bollards. I gathered lots of blocks of bollards on http://www.kantengineering.com/Autocadblocks.com. Now I am trying to do the same on my English site http://www.acad-blocks.com, but that is a bit harder.
rob s
Newbie
Posted: 15.Oct.2010 at 21:41 |
I added some blocks of bollards on my website http://www.acad-blocks.com. If you need other blocks just fill in the request form on the same site. |
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,125 seconds.
Topic Options
