Over 1.125.000 registered users (EN+CZ).
Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
margarita9
Newbie
Joined: 19.Feb.2011 Location: Greece Using: autocad 2008 Status: Offline Points: 1 |
Topic: visual styles------PLEASE HELPPosted: 20.Feb.2011 at 01:16 |
Hello! :)
I was wondering if anyone could help cause I am really stuck here.. I have a problem with Autocad views. Basically I am changing the options in Visual Style Manager to find the one that matches my needs but I cannot find it.. The point is to make a visual style that is as realistic as possible without the isolines and full exposure of materials and textures.I have a presentation at Wednesday and I dont have the time for photorealistic results so I want to take full advantage of the visual style options. When I move the 3d model I made(its an office building) its like it changes the visual style and that is the one I need..But when I stop moving it with constained orbit command it returns to the custom visual style which sucks for the presentation!!!!!!Please someone help me its very important...I really need to do something so that it looks real....... Every advice will be considered......Forgot to mention Im using Autocad 2008!!! Thank you very very very much !!!!!!!!!!!!!!!!!!! :)
John Connor
Senior Member
Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 20.Feb.2011 at 02:43 |
You are aware that you can create a custom visual style right?
Which one are you currently using? Is it close to what you want but not exact? |
<<AutoCAD 2015>> |
HAWDesigner
Senior Member
Joined: 04.Aug.2008 Location: United States Using: AutoCAD R14, AutoCAD 2009, AutoCAD 2010 Status: Offline Points: 310 |
Posted: 20.Feb.2011 at 14:56 |
margarita, it sounds like you have most of it under control already. It sounds to me like you want to use the Realistic Visual Style with a couple minor changes.
In the Visual Style Manager (command: VISUALSTYLES) select the Realistic Visual Style, you can adjust the settings below to your liking. In the Materials and Color section, set your Material Display setting to "Materials and Texture". Then, in the Edge Settings section, set your Edge Mode to None. OR, what I like to do is leave the Edge Mode to Isolines and just change the color of the Isolines to "ByEntity". This way they're kinda hidden. Anyways, once you have the settings set, change the drawing to the view you want. If you're printing from modelspace, then just right-click on the Realistic Visual Style and select "Apply to Current Viewport". If you're in Paperspace, then you need to double-click in an unlocked viewport, right-click on the Realistic Visual Style and select "Apply to Current Viewport". Do this as many times as you need for each view port on the sheet. I hope this helps. Good Luck!!! A side tip for using 3DOrbit: Instead of typing in a command to enter the 3D mode, just press and hold down your shift key while you press your mouse wheel and drag the mouse around to the position you want the screen. It is much faster and you can often get better results. Edited by HAWDesigner - 20.Feb.2011 at 14:58 |
R. Williams AutoCAD 2010 Certified Professional <!-- If all else fails hit F1 --> <<AutoCAD 2009 |
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,095 seconds.
Topic Options
