RSS discussions
Discussion Discussion forum
Topic ClosedScale problem
 Post Reply Post Reply
Author
3smees23 View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Topic: Scale problem
    Posted: 31.Mar.2008 at 14:51
Hi all,
i have recently taken over a role which involves making schematics for a security company.  i have started to design my own template but i need the pre existing blocks as they are a standard for the company.
The problem that im having is that when i insert my blocks from block editor using either the conventional way or by dragging and dropping from the design centre they get warped.
please could someone tell me how to insert a pre existing block (explaining setting the base point, scale and rotation)?
Is it possible to drag the block over the page and create a box so it fits it perfectly? rather than having to mess around with the scale command.
sorry if this is basic, i have only had a short course and i cant ask anyone in the company.  thanks
sam
Back to Top
Vladimir Michl View Drop Down
Senior Member
Senior Member
Using: Autodesk software
Status: Offline
Direct Link To This Post Posted: 01.Apr.2008 at 15:15
You can use the Tool palettes to prepare a set of standard blocks for easy insertion, including their scale, layer and rotation settings.
Another way is to use a macro (Diesel, LISP, VBA) to insert your blocks. For autorotation you can also use the dynamic blocks.
Vladimir Michl
//CADs.cz, LinkedIn
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,117 seconds.
