RSS discussions
Discussion Discussion forum
Topic ClosedProblem with mirrored attributes
 Post Reply Post Reply
Author
ciakki View Drop Down
Newbie
Newbie
Using: Autocad 2010
Status: Offline
Direct Link To This Post Topic: Problem with mirrored attributes
    Posted: 09.Jun.2011 at 14:18
Hi,
I got a problem basically with text allignment:
In my drawing there is a block repeated, rotated and mirrored several times. I need to add to this block another block to implement the dwg. I open the block editor and i add my block to the existing one and everything works fine. When i go out from the block editor my block that contains a text attribute seems to have some troubles managing the text because sometimes is mirrored.
http://img841.imageshack.us/img841/3203/mirroredc.png <- paste this to view a pic of the problem
I dig out the internet and i found the tecnique to use the -1 value to the scale of a block to mirror it, and i think that the problem is related to this because the text messes up where the block as a negative scale value.
Does anyone knows hot ti fix this?
thanks
CiaKKi
Edited by ciakki - 09.Jun.2011 at 14:19
Back to Top
philippe JOSEPH View Drop Down
Senior Member
Senior Member
Using: AutoCAD Mechanical 2017
Status: Offline
Direct Link To This Post Posted: 10.Jun.2011 at 11:07
TRY TO SET "MIRRTEXT"
(0) --> THE TEXT IS NOT MIRRORED
(1) --> THE TEXT IS MIRRORED
Back to Top
Vladimir Michl View Drop Down
Senior Member
Senior Member
Using: Autodesk software
Status: Offline
Direct Link To This Post Posted: 10.Jun.2011 at 11:15
It might get more complicated if the block is a dynamic block. See:
Vladimir Michl
//CADs.cz, LinkedIn
Back to Top
Newbie
Newbie
Using: Autocad 2010
Status: Offline
Direct Link To This Post Posted: 10.Jun.2011 at 11:22
I tried for first but mirrtext is ot involved in this case, thanks man.
I see, i'll make some tries.
But i found what is the cause of the trouble and i think i step over a bug.
The porblem occurs only if i go to the block editor to edit the visualiztion order. If I do that the text goes crazy.
Back to Top
titashtalukdar View Drop Down
Newbie
Newbie
Using: Autocad 2024
Status: Offline
Direct Link To This Post Posted: 14.Jun.2011 at 08:05
Open the block in BEDIT, then replace what you need to replace. Save & Close the Block Editor, and come out. Then try and use ATTSYNC, ( Attribute Synchronization).
ar.titashtalukdar
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,480 seconds.
