RSS discussions
Discussion Discussion forum
Topic ClosedAutocad LT Software & License Transfer
 Post Reply Post Reply
Author
griartejm View Drop Down
Newbie
Newbie
Using: AutoCAD2011
Status: Offline
Direct Link To This Post Topic: Autocad LT Software & License Transfer
    Posted: 14.Jun.2011 at 07:50
Hi, I'm using AutoCAD LT(Stand-alone license) in my desktop computer,  Now, i need to transfer my AutoCAD in my laptop for a reason. Now the question is, Is it possible to transfer AutoCAD Software & License from one unit to another? and How. Many Thanks guys!
Balot Penoy!
Back to Top
Vladimir Michl View Drop Down
Senior Member
Senior Member
Using: Autodesk software
Status: Offline
Direct Link To This Post Posted: 14.Jun.2011 at 07:54
Yes, there is the License Transfer Utility (either local or online - depending on your LT version).
Vladimir Michl
//CADs.cz, LinkedIn
Back to Top
Newbie
Newbie
Using: AutoCAD2011
Status: Offline
Direct Link To This Post Posted: 14.Jun.2011 at 08:00
ok, By the way im using AutocadLT 2011, i've already read about LTU, but im a bit confuse becaus in autodesk website they didn't give any instructions regarding that matter, So have you tried it? im a bit scared to try.
Balot Penoy!
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 14.Jun.2011 at 08:09
There are no major problems with this tool. It has its own help. Just login from the source computer, export the license, login from the target PC and import the license.
Vladimir Michl
//CADs.cz, LinkedIn
Back to Top
Newbie
Newbie
Using: AutoCAD2011
Status: Offline
Direct Link To This Post Posted: 14.Jun.2011 at 08:16
what should be my first step?
 uninstall autocad from my desktop & reinstall to my laptop? then connect to LTU website?
Balot Penoy!
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 14.Jun.2011 at 10:12
Have LT installed on both computers. Then perform the LTU transfer.
Vladimir Michl
//CADs.cz, LinkedIn
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 14.Jun.2011 at 11:57
Do you want to have the ability to use AutoCAD on both computers (just not concurrent use)?  If so then you do NOT want to uninstall AutoCAD from the desktop computer.  On the other hand, if you no longer want AutoCAD on your desktop computer then go ahead and uninstall it after running the license transfer utility.
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,262 seconds.
