Over 1.127.000 registered users (EN+CZ).
Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
kc13
Groupie
Joined: 02.Jan.2012 Location: United Kingdom Using: Autocad 2024 Status: Offline Points: 50 |
Topic: TrimPosted: 02.Jan.2012 at 22:24 |
i am having problems with the trim command. it is only selecting the last line which ever one i am selecting, and straight away de-selecting others, please help, many thanks
kc
John Connor
Senior Member
Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 02.Jan.2012 at 22:49 |
Sounds like a system variable has been reset.
Try setting both PICKFIRST and PICKADD to a value of 1 and that should solve all pick-related problems. Edited by John Connor - 05.Jan.2012 at 11:30 |
<<AutoCAD 2015>> |
heinsite
Senior Member
Joined: 05.Feb.2009 Location: United States Using: AutoCAD 2014 Status: Offline Points: 640 |
Posted: 05.Jan.2012 at 06:57 |
What John meant to type was PICKFIRST.
![]() The best tip I know of with the TRIM command is to just hit the return key at the "Select objects" prompt, and not waste time selecting things... or missing something. By doing this you select everything and therefore everything in the drawing becomes a potential cutting object. Saves a lot of time. Dave |
Dave Hein, P.E.
Hawaii District Engineer Kona International Airport AutoCAD Certified Professional Autodesk Expert Elite |
John Connor
Senior Member
Posted: 05.Jan.2012 at 11:32 |
Dave: Doesn't that technique require a "double tap" of the ENTER key?
<<AutoCAD 2015>> |
heinsite
Senior Member
Posted: 05.Jan.2012 at 23:19 |
uploads/20120105_231841_TrimExample.dwg
John,
After the initial TRIM command, yes. But it's not much different than clicking cut objects.
Try it with the attached example. TRIM at the command line and ENTER to Select all. Then use a crossing window to trim all the red lines to the whites and all the whites to the reds.
Bob's your uncle.
Dave.
Edited by heinsite - 05.Jan.2012 at 23:25 |
Dave Hein, P.E.
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,070 seconds.
Trim
Topic Options
