RSS discussions
Discussion Discussion forum
Topic ClosedAcad2011 commands compromised
 Post Reply Post Reply
Author
zippypinhead View Drop Down
Newbie
Newbie
Using: AutoCadR14
Status: Offline
Direct Link To This Post Topic: Acad2011 commands compromised
    Posted: 18.Jan.2012 at 01:30
I've been using 2011 for about nine months now. (finally updated from R14)
I recently imported an IGES file and now my commands are all wonky.
If I try to erase multiple lines/circles etc, it'll only do one at a time. Pick on one, go to pick on the next and the last one loses it's highlight and won't erase.
Trying to trim; if you pick on one line as a border, the next one you pick cancells the last....
Seems to be doing it on a bunch of commands in a similar fashion.
What did I do???? What should I do?
Thanks for looking
Zippy
Edited to add: Does the same funky thing on any drawing I open so I doubt if it's related to the iges import.... Must've fat-fignered some key.... Which one I wouldn't have a clue.
Edited by zippypinhead - 18.Jan.2012 at 01:50
Back to Top
heinsite View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 18.Jan.2012 at 03:07
PICKADD is probably set to <0>.  Set it to <2> and see what happens.
Dave.
Dave Hein, P.E.
Hawaii District Engineer
Kona International Airport
AutoCAD Certified Professional
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 18.Jan.2012 at 12:13
You want both PICKFIRST and PICKADD to be set to a value of "1".
They are system variables that can be changed at the command line.
How did either or both get changed?  You could have used a poorly written lisp routine that reset the variables and forgot to return them to their original settings.
Edited by John Connor - 18.Jan.2012 at 12:40
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 18.Jan.2012 at 20:09
PICKFIRST only controls whether you can select objects before (noun-verb selection) or after issuing a command.  It won't have any effect on objects disappearing or not with new selections.  That's handled by PICKADD.
A PICKADD setting of "0" requires holding the SHIFT key down to add additional items.  A setting of "1"  will add new selections to the selection set.  With "1", holding down the SHIFT key will remove objects or selections.
AutoCAD 2011 added setting "2", and it works just like "1" except that when using the ._Select command, the entities remain selected when the command is over. Previously when you used the ._Select command then executed a command, you had to use _P to refer to the previous selection set. Now you can use the ._Select command, create a selection and then launch the desired command with the selected objects pre-selected.
Most people use "1" as John suggests.  Mine was a "just in case" option.
Dave.
Edited by heinsite - 18.Jan.2012 at 20:12
Dave Hein, P.E.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 18.Jan.2012 at 20:28
I always suggest changing/checking both as to avoid having to answer a second question regarding the "other" variable I missed.  Saves time.
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 18.Jan.2012 at 20:38
Fair enough.
You have to dig deep to find a good explanation of what is different about "2" in PICKADD tho'... the ACAD help file (at least on my 2011 system) has the same exact paragraph description for "1" and "2"!
Dave.
Dave Hein, P.E.
Back to Top
Newbie
Newbie
Using: AutoCadR14
Status: Offline
Direct Link To This Post Posted: 20.Jan.2012 at 19:08
PICKADD was the ticket. Dunno how I managed to change the setting. I don't even know what a lisp routine is much less what a poorly written one would be...
Thanks guys.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 20.Jan.2012 at 19:52
There's a menehune near your computer then... that's a whole other issue.  Wink
Dave.
Dave Hein, P.E.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,216 seconds.
