RSS discussions
Discussion Discussion forum
Topic Closedhatches
 Post Reply Post Reply Page  12>
Author
Tommurph View Drop Down
Newbie
Newbie
Using: ARCHITECTURE 2010
Status: Offline
Direct Link To This Post Topic: hatches
    Posted: 02.Aug.2013 at 02:01
I am using ADT 2010 and hatches have disappeared as well as background masks don't mask either.  This seems to be drawing related.  Anyone have any idea why?
Tom M.
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 02.Aug.2013 at 11:50
Did you check for layers that are off or frozen?
Are xrefs being used?
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 02.Aug.2013 at 17:13
All layers are turned on.  I can see a frame around the hatches and around where the background mask should be (if I use a color for the background mask it will show up as a frame around the text).  I think a command did this as it showed up after working on the drawing a while.  If I start a new drawing the hatches and background mask work as they should.
Tom M.
Back to Top
thinker View Drop Down
Groupie
Groupie
Using: AutoCAD2024
Status: Offline
Direct Link To This Post Posted: 12.Aug.2013 at 08:18
check the fill command either it is on or not
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 12.Aug.2013 at 12:31
You may have to issue a REGEN command too after turning FILL on.
<<AutoCAD 2015>>
Back to Top
kad.lntecc View Drop Down
Newbie
Newbie
Using: AUTOCAD 2013
Status: Offline
Direct Link To This Post Posted: 31.Aug.2013 at 14:05
hi..,
I using AutoCAD 2013 & 2014 .Every time when I was open dwg file hatches have disappeared.
every time I have use "Fill command" use on & then enter region then only can see the hatches...
please tell the solutions.. 2 times I was uninstalled & then install a twice , again the same issues..
kindly give me the solutions...
 regards..
KRISHNA..
KRISHNA.G
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 01.Sep.2013 at 15:16
Are you sure all your geometry has a "Z" of "0"?
<<AutoCAD 2015>>
Back to Top
Bobdob View Drop Down
Groupie
Groupie
Using: About to learn
Status: Offline
Direct Link To This Post Posted: 01.Sep.2013 at 19:48
Hi all,
Please forgive my rudeness by posting on this topic but I just can't post a thread on this forum. Im a newbie and have just registered but I haven't been able to post a new thread. Please can someone help me with this?
Once again, I am sorry for hijacking this thread.Confused
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 01.Sep.2013 at 22:31
Only a moderator or owner of the site can help you.  Us mere mortals are powerless.
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 01.Sep.2013 at 22:43
Thanks for that, much appreciated. However, I don't know how to contact one?
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,092 seconds.
