Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
ist4000
Newbie
Joined: 23.Aug.2013 Location: Germany Using: AutoCAD2013 Mac Status: Offline Points: 16 |
Topic: Surfaces to solidsPosted: 26.Aug.2013 at 13:24 |
Hello!
I created an object with surfaces and can't modify it to a solid. Could anyone please suggest me how to do it? I created the surfaces as needed by the commands SURFNETWORK, Planesurf and loft. The white lines are sections. uploads/399360/rig_hh_4_sections.dwg Thanks in advance ![]() |
Vladimir Michl
Senior Member
Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2196 |
Posted: 26.Aug.2013 at 13:48 |
Try to convert it to NURBS Surfaces, then UNION and then CONVTOSOLID. I had some (limited) success with this workflow on your model.
ist4000
Newbie
Posted: 26.Aug.2013 at 14:05 |
CONVTONURBS did not work:
Command: _CONVTONURBS 5 found 5 not selected, not a valid object type. Did I something wrong? |
Vladimir Michl
Senior Member
Posted: 26.Aug.2013 at 14:26 |
There are several LINES and SPLINES in your drawing - they were not converted, but the rest was. You can also delete them with QSELECT.
ist4000
Newbie
Posted: 27.Aug.2013 at 13:24 |
Worked. Thank you!
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,156 seconds.
Surfaces to solids
Topic Options
