CAD tip # 13091:
applies to: AutoCAD · |
Tip 13822: | Fast layer visibility toggle ON/OFF. |
Tip 13227: | Reference Explorer - quick analysis of your project or assembly (file size, xref errors). |
Tip 13211: | Automatic numbering/renaming of multi-volume bodies in a part. |
Tip 12105: | Select the smallest DWG object - MinOf utility. |
Tip 12036: | Sel2BlkRef (blockify) - replace repeating objects with block references |
Text is printed randomly from Inventor sketch mode.
How to change material texture orientation in Fusion 360? « | » 3DintCurves - intersections of curves with 3D solids.
Featuring: Use Google Earth images in your AutoCAD projects with the Plex.Earth Tools ![]() |
