  Visitors: 5866
CAD tip CAD tip # 13211:
Automatic numbering/renaming of multi-volume bodies in a part.
A - answer If you like to use multi-volume bodies as control models for assemblies, you can save yourself the trouble of naming the files when exporting to an assembly when you need to distinguish the bodies, e.g. number them. Manually overwriting names/numbers would be inconvenient. Use the following iLogic rule (macro) to automate such 'renaming by numbering'.
The solids will be named (renamed) according to the specified prefix followed by a numeric series.
'------- start of iLogic ------
'original idea: B.Han
'check that this active document is a part file
Dim partDoc As PartDocument
If ThisApplication.ActiveDocument.DocumentType <> DocumentTypeEnum.kPartDocumentObject Then
    MessageBox.Show("Please open a Part document", "iLogic")
    Return
End If
'define the active document
partDoc = ThisApplication.ActiveDocument
'check for custom iProperty and add it if not found
Dim prefixPropertyName As String = "Prefix"
Dim customPropertySet = partDoc.PropertySets.Item("Inventor User Defined Properties")
Dim prefixProperty As Inventor.Property
Try
    prefixProperty = customPropertySet.Item(prefixPropertyName)
Catch
    ' Assume error means not found
    prefixProperty = customPropertySet.Add("", prefixPropertyName)
End Try
'write the part number to the Prefix iProperty if it is empty
If String.IsNullOrEmpty(prefixProperty.Value.ToString()) Then
    prefixProperty.Value = iProperties.Value("Project", "Part Number") & "_"
End If
'get input from user
Dim bodyPrefix = InputBox("Enter a prefix for the solid body names", "iLogic", prefixProperty.Value.ToString())
'write input back to custom iProperty
prefixProperty.Value = bodyPrefix
'rename all solid bodies incrementing suffix
Dim i As Integer = 1
For Each solid As SurfaceBody In partDoc.ComponentDefinition.SurfaceBodies
    solid.Name = String.Format("{0}{1:00}", bodyPrefix, i)
    i += 1
Next
'------- End Of iLogic ------
Submited by: M.Depta, thanks
Inventor
3.2.2022    2543×
Prices - CAD eShop:
applies to: Inventor ·
Tip 13611:BOM with multi-line items in Inventor.
Tip 13536:iLogic: How to find if a document is a sheet metal part and if it contains holes?
Tip 13040:iLogic - display information about complexity of an Inventor part.
Tip 12828:How to quickly delete 3rd party links to external objects in Inventor?
Tip 12644:How to identify parts and assemblies imported from STEP/IGES?
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
