  Visitors: 10619
CAD tip CAD tip # 13095:
How to change material texture orientation in Fusion 360?
A - answer In the Appearance library, material maps (textures, bumps, transparency) are oriented by default according to the UV vectors of the faces to which the materials are applied.
If you want to uniformly change the orientation of such a material or its maps (wood grain, paint patterns, sheetmetal grain, fabric or leather texture, transparency grids, etc.), you can edit (rotate) the material in the Appearance library. The procedure for changing the Rotation parameter is shown in the video.
Fusion360
13.10.2021    6616×
Prices - CAD eShop:
applies to: Fusion 360 360 ·
Tip 13824:How to export OBJ including materials, textures from Inventor?
Tip 13557:How to create an image with transparent background in Fusion 360?
Tip 12314:How to display OBJ models including textures in A360?
Tip 12178:Modelling 3D knurling - e.g. knurled surface of a control knob.
Tip 11464:How to make a fast Inventor Studio animation without rendering?
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
