Over 1.092.000 registered users (EN+CZ).
AutoCAD tips, Inventor tips, Revit tips.
New AutoCAD 2026 commands and variables.
CAD tip # 13615:
Question
Starting with AutoCAD 2017 (incl. the LT version), you can use the CENTERMARK and CENTERLINE commands to create associative axes of symmetry on your DWG drawing geometry. This allows you to create, for example, a bisector of an angle, an axis of a polyline, or easily draw the center of an arc.
See sample use:
You can disassociate the axes or use grips to resize them.
These axes are a special type of a block reference (INSERT). They appear as "Axis" and "Center mark" in the Properties palette or in the QSELECT dialog.
ACADACLT
26.1.2023
14979×
applies to: AutoCAD · AutoCAD LT ·
