Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 8745:
Question
If you have moved your AutoCAD command line (2013 and higher) off screen by mistake - e.g. by mouse dragging, or by connecting off a second monitor, or by changing your screen resolution (projector) - you can return it back using a simple change in the CUI dialog.
CUI (CZ version)
For the current workspace expand the Palettes and locate the "Command Line" item. Here change the properties Show to "Yes" a Orientation e.g. to "Bottom". Apply/confirm the changes. Your command line will be again docked at the bottom of the drawing window. You can drag it to the desired position.
For older versions use the Tip 8018.
ACAD2013ACLT2013
7.8.2012    24046×
Share the tip:
applies to: AutoCAD 2013 · AutoCAD LT 2013 ·
Tip 13723:How to tear and drag a DWG drawing window to a second screen?
Tip 12287:AutoCAD hatch flood-fill does not honor all boundaries.
Tip 11623:Measuring suddenly doesn't work in AutoCAD or DWG TrueView.
Tip 11492:Adding selected numbers in drawing texts - counting numbers (GrSelNum).
Tip 11276:Inactive drawing, inactive commands after starting AutoCAD.
Back    All CAD Tips
Categ:
LogOff 2006 More info
