Over 1.092.000 registered users (EN+CZ).
AutoCAD tips, Inventor tips, Revit tips.
New AutoCAD 2026 commands and variables.
CAD tip # 11623:
Question
Instead of the measured distance, AutoCAD suddenly displays only the crosshair cursor with a question mark badge (symbol), no numbers.
Please check the commandline prompt for the expected type of the entry. The older command DIST immediately prompted for the points to measure. The newer universal measuring command MEASUREGEOM first requests to specify the measurement type (distance, area, radius, volume, angle...) and then prompts for the individual points.
The Dynamic mode (F12) displays prompts and measured data on screen. If it is disabled, the prompts may be somewhat hidden, especially if your command line is disabled or minimized.
ACADACLTDWG
23.9.2017
40306×
