Over 1.095.000 registered users (EN+CZ).
AutoCAD tips, Inventor tips, Revit tips.
New AutoCAD 2026 commands and variables.
CAD tip # 7680:
Question
You can use multiple formats to export your scene from Autodesk 3ds Max to Inventor or other 3D modeler. The Export function in 3ds Max offers e.g. the following conversion formats compatible with Inventor (can be imported in Inventor):
- AutoCAD DWG
- AutoCAD DXF
- ACIS SAT
- IGES
The preferred option is ACIS .SAT, available in the version Max 2011 (and higher) and in Max 2010 with the "Connnection Extension".
max2011Inventor
10.12.2010
24726×
applies to: 3ds Max 2011 · Inventor ·
