Over 1.096.000 registered users (EN+CZ).
AutoCAD tips, Inventor tips, Revit tips.
Try the new precise Engineering calculator and the updated Barcode generator.
New AutoCAD 2026 commands and variables.
CAD tip # 7210:
Question
AutoCAD 2010 can select subobjects of a given entity by holding the Ctrl key when selecting the entity. With the CTRL key you can e.g. select only some segments of a polyline.
The grips of the selected segments will automatically become hot (selected) grips and you can directly modify these segments (e.g. move) using grip-editing.
This behaviour is can be suppressed with the LEGACYCTRLPICK variable.
ACAD2010ACLT2010ADT2010Civil2010Map2010
9.2.2010
14471×
applies to: AutoCAD 2010 · AutoCAD LT 2010 · AutoCAD Architecture 2010 · Civil 3D 2010 · AutoCAD Map 3D 2010 ·
