Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 13988:
Question
An interrupted installation, a missin reboot, or other disruption of the installation mechanism may leave Windows CAD applications or updates that cannot be uninstalled in the standard way and also cannot be reinstalled (the installation reports that they are already installed).
In these cases, a manual uninstall is usually necessary (if possible), or in the case of Autodesk applications (2022 and above), you can run an "unconditional" uninstaller for that application or update (e.g. hotfix).
These uninstaller tools can be found in the subfolders of the folder C:\ProgramData\Autodesk\Uninstallers\ - e.g. C:\ProgramData\Autodesk\Uninstallers\Civil3D2024.3Update or C:\ProgramData\Autodesk\Uninstallers\Autodesk Revit 2024.1.1 Update. In such folders, you will always find the program AdskUninstallHelper.exe, after which launch the CAD program or update (all its components) will be uninstalled. The uninstallation takes place in a text window, with information about the ongoing steps.
Uninstalling (by any method) does not remove the uninstaller itself.
This procedure replaces the older "Autodesk Uninstall Tool".
ACADADTPlantACADMCivilMapACLTRevitInvMax
10.1.2024    7840×
Share the tip:
Tip 12412:Missing category icons and thumbnails in Inventor Content Center.
Tip 10408:Autodesk Application Manager reports it has been retired.
Tip 10274:Installation or update problem in Autodesk Fusion 360 (locked).
Tip 10021:Autodesk Application Manager hangs reporting no updates.
Tip 9882:How to disable the Autodesk 360 cloud functions in AutoCAD?
Back    All CAD Tips
Categ:
Generate hatch patterns automatically from your DWG drawings with
HGEN 2006 More info
