  Visitors: 8059
CAD tip CAD tip # 8765:
How to get and install a localization for Revit 2013?
A - answer Revit localizations (German, French, Spanish, Russian, Czech, etc.) in a form of additional "Language Packs" (LP), one of the new features in version 2013, work differently than with other Autodesk products (see the Tip 8580).
You cannot install this LP and an add-on installation, you can only include it in the product installation. Another option is to download and install the full localized version of Revit 2013 (or the respective Building Design Suite 2013).
Steps to install LP:
  1. download the requested language pack from your Subscription center, from the Download section. Language packs are available for Revit Architecture, Revit MEP, Revit Structure and Revit 2013 ("all-in-one")
  2. Unpack the saved file
  3. Run the Revit installation and in the list box Product Language choose Add Language Pack...
  4. Select the appropriate *.msi file (they differ between 32-bit and 64-bit systems)
  5. Complete the installation
Revit2013BDS
16.8.2012    8636×
Prices - CAD eShop:
applies to: Revit 2013 · BDS ·
Tip 13683:Limitations of the LISP language (AutoLISP, VisualLISP) in AutoCAD LT - what to watch out for
Tip 12524:Overview of Revit runstring parameters (for Revit.exe)
Tip 10702:How to find which AutoCAD version was used to save a particular DWG drawing?
Tip 10283:Where to find Language Packs for Revit 2016?
Tip 10154:Error "You do not appear to have any language database files installed." in Simulation Mechanical Fatigue Wizard.
Automatic nesting of 2D parts on rectangular sheets in AutoCAD
AutoNEST 2008 More info
