Over 1.096.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator and the updated Barcode generator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 14451:
Question
If you use the "Do not capture Design History" feature in Autodesk Fusion and confirm the "Clear Design History" dialog, the model history timeline will be irreversibly removed from the current design and Fusion will be in the Direct modeling mode.
Removed design history cannot be restored or otherwise reconstructed.
If you restore design history capture (e.g. by right-clicking on the root element of the model tree and selecting "Capture design history"), only subsequent design features will be captured, the original model will remain as a "Base Feature".
The easiest way to return to the original model with the captured history is to open a previous version of the design - see Tip 13770.
Fusion360
100% *CAD,CAM
12.3.2025    2108×
Share the tip:
applies to: Fusion 360 360 ·
Tip 14240:How to simplify an uneven profile imported via DXF into Autodesk Fusion?
Tip 14022:Comparing design versions in Autodesk Fusion.
Tip 13770:How do I revert to a previous version of the model in Fusion 360?
Tip 13402:Which products and features can I use for free with Flex Token licensing?
Tip 13032:How to prepare a 3D model for manufacturing by removing detailed elements?
Back    All CAD Tips
Categ:
VRMLout More info
