  Visitors: 8428
CAD tip CAD tip # 9754:
How to switch the AutoCAD 2015 dark scheme back to the light one?
A - answer If you don't like the dark color scheme (theme) in AutoCAD and you want to use the contrasting light appearance (the old one), set the COLORTHEME variable to 1.
This setting is stored in the Registry and applies to all subsequent sessions. You can also set this option in the Options dialog, on the Display tab (Color scheme).
ACAD2015LT2015ACADM2015Civil2015Plant2015
28.3.2014    7560×
Tip 13868:XrefStamp - create a dynamic list of xrefs in your DWG drawing.
Tip 13843:Accented characters (umlauts) are incorrectly displayed in the material schedule on isometric drawing.
Tip 13809:AutoCAD displays continuous lines and texts as dotted.
Tip 13802:Dual-color hatches in AutoCAD.
Tip 13597:How to convert RGB color to Pantone, RAL, AutoCAD ACI, CMYK or vice versa?
