Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 7433:
Question
AutoCAD 2011 (and the whole Autodesk 2011 family) introduces a new alignment (orientation) type for texts in complex linetypes.
In the .LIN linetype definitions with texts or symbols, it has been possible to use the "R" code for relative rotation of the text against the orientation of the line segment, or the "A" code for absolute orientation. The usually used values were only 0 and 90°.
AutoCAD 2011 now offers also another alignment code "U". This code ensures an "always readable" text, i.e. the upright orientation in all directions of the line segments.
Compare the display mode of the standard AutoCAD linetype GAS with the code R and with the new code U:
*GAS,Gas ----GAS----GAS----GAS----GAS----GAS----GAS--
A,12.7,-5.08,["GAS",STANDARD,S=2.54,U=0.0,X=-2.54,Y=-1.27],-6.35
Linetype alignment
You can use the utility CADstudio LTfly (see Download) for an automatic definition of a linetype with an embedded text. This tool automatically uses the U-code for AutoCAD 2011.
ACAD2011ACLT2011ADT2011Civil2011
29.6.2010    35559×
Share the tip:
Tip 14509:AutoCAD linetypes - the A/R/U orientation options in complex text-linetypes.
Tip 12392:Export unfolds of sheetmetal parts to DXF - parameters for iLogic and VBA
Tip 10855:Dynamic linetype scaling by mouse dragging.
Tip 10028:My linetype does not reverse. Why?
Tip 9829:DrGrid - parametric grid for AutoCAD drawings.
Back    All CAD Tips
Categ:
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
