CAD tip # 7758:
Tip 13333: | "Zero length line" warnings or misplaced vertices when importing vertex coordinates from scripts. |
Tip 13185: | Constraining object movement to a specified curve (rail) in AutoCAD. |
Tip 12896: | How to perform multiple copying with relative offset to the last copy? |
Tip 12766: | Lines with a single grip, incorrect osnaps, intersections, offsets, hatches - CheckLarge |
Tip 12705: | How to disable osnaps for xref objects? |
Featuring: Increase your productivity with our set of BIM add-on functions for Autodesk Revit CADstudio Revit Tools ![]() |
