  Visitors: 7408
CAD tip CAD tip # 1127:
How to enter russian (cyrillic) text into your AutoCAD drawings?
A - answer Since Rel.13 AutoCAD uses Unicode character coding (2-byte) so you can use any language/coding for your drawing texts. Windows 9x/ME use 8-bit codepages for multilanguage texts, we recommend to use Windows NT, 2000, XP or higher for true Unicode support.
So how to enter eg. russian text? Just install/add the required language support (eg. Russian) from your Windows installation media. This adds a "locale" keyboard driver. Use one of the standard Unicoded fonts (so you don't need any special font, like cyrillic.shx) for your texts (eg. Arial, Times Roman, IsoCP). Use MText (not DText).
ACADLTADTMDTMap
100% Win  CAD
14.3.2001    28078×
Prices - CAD eShop:
Tip 12562:How to display cyrillic or special math symbols in a DCL dialog?
Tip 12069:Unicode and DXF files.
Tip 11580:Excel: convert Unicode texts to \U+ codes for AutoCAD
Tip 7520:DWG to PDF problem in an arabic font.
Tip 7164:The NLS files required to convert the text entities...
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
