  Visitors: 4514
CAD tip CAD tip # 1497:
How to save the contents of AutoCAD system variables and transfer it to another computer?
A - answer Most variables are saved directly in the drawing so you transfer them with the DWG file. Variables saved in the Registry can be transferred using a User profile.
You can also use the Express tools - "System Variable Editor" (SYSVDLG) which can save current status of variables to a SVF file and then restore them from this file again (import/export).
ACAD
24.7.2001    10039×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 13683:Limitations of the LISP language (AutoLISP, VisualLISP) in AutoCAD LT - what to watch out for
Tip 13635:How to speed up background publishing in AutoCAD?
Tip 13522:LookupXLS - populating DWG texts from Excel spreadsheets.
Tip 13514:Why does the Power dimensioning command zoom my drawing?
Tip 13296:How to correctly load a KML/KMZ file into Civil or Map 3D?
