  Visitors: 4357
CAD tip CAD tip # 3541:
"Topology is correct and incomplete" but it cannot be deleted.
A - answer Delete the complaining topology manually using the command:
MAPTOPOADMIN _Delete {topology_name} _N _Y
Map5Map5Map2004
21.1.2004    4851×
Prices - CAD eShop:
Tip 10416:How to fix/repair large 3D mesh models?
Tip 10383:The shortest path between two points on a network.
Tip 10128:How to convert a line-based map to closed polygons (lots)?
Tip 10102:How to simplify a complex 3D mesh model?
Tip 4068:How to find the polyline direction/orientation?
VRMLout More info
