  Visitors: 3443
CAD tip CAD tip # 3698:
How to read ArcInfo 'export' files into AutoCAD?
A - answer The .E00 format files from Arc/Info cannot be read in AutoCAD or Map (up to the version 2004). But you can use a free utility by ESRI which will convert E00 files to Arc-Info coverage - you can load coverage files to Autodesk Map using the Import function (or use them directly in Autodesk MapGuide).
AutoCAD Map 3D 2005 (and higher) supports the E00 format files directly.
MapMap2005ACADMapGuide
30.3.2004    11711×
Prices - CAD eShop:
Tip 13694:Individual modification of elements in AutoCAD dynamic arrays.
Tip 13622:Bulk import pages from a multi-page PDF into AutoCAD.
Tip 13604:Importing points from a Shape file as symbols/blocks mapped to object data.
Tip 13296:How to correctly load a KML/KMZ file into Civil or Map 3D?
Tip 13056:How to copy DWG Properties from one drawing to another?
