CAD tip # 4576:
applies to: AutoCAD 2006 · AutoCAD LT 2006 · |
Tip 13757: | Bulk editing of drawing properties (DWGprops) from Excel. |
Tip 13737: | Formatting leading zeros in AutoCAD fields (and automatic field update). |
Tip 13522: | LookupXLS - populating DWG texts from Excel spreadsheets. |
Tip 12837: | RenameCSV - rename layers, blocks, layouts, views, linetypes using Excel tables |
MDT can not find Excel 2000 Deutsch (German)version.
Why does AutoCAD insert my blocks in wrong scale? « | » How to add an attribute to a block used in a drawing?
