  Visitors: 2922
CAD tip CAD tip # 5976:
Keyboard shortcuts defined in AutoCAD.
A - answer The standard AutoCAD menu (MNU/MNS/CUI) defines the following hotkeys:
F1 displays help
F2 displays text window (Ctrl+F2 since 2014)
F3 switches object snaps
F4 toggles table mode
F5 toggles isometric planes
F6 toggles DUCS (switches coordinate display, till A2006)
F7 toggles grid display
F8 toggles ortho mode
F9 toggles snap
F10 toggles polar tracing
F11 toggles object tracing
F12 toggles dynamic input (2006+)
ESC cancel changes, cancel grips
TAB cycles osnaps
SHIFT (on object selection) removes objects
DEL erases objects (hold when pointing)
Ctrl+0 toggles clean-screen mode (2004+)
Ctrl+1 displays Properties window
Ctrl+2 displays DesignCenter window
Ctrl+3 displays Tool palette (2004+)
Ctrl+4 displays Sheet Set Manager, or Content Manager (2005+, ADT2004)
Ctrl+5 displays Info Palette, or Project Navigator (2005-2007, ADT2004)
Ctrl+6 displays dBConnect window
Ctrl+7 displays Markup Manager (2005)
Ctrl+8 displays Quick Calculator (2006+)
Ctrl+9 shows/hides Command line (2006+)
Ctrl+A selects all thawed objects (2002)
Ctrl+Shift+A toggles group selection (group/single)
Ctrl+B toggles snap
Ctrl+C copies content to Clipboard
Ctrl+Shift+C copies with reference point
Ctrl+D toggles coordinates display (dynamic UCS, till 2009)
Ctrl+E switches isoplanes
Ctrl+Shift+E pull a region to 3D (PRESSPULL, since 2010)
Ctrl+F toggles osnaps
Ctrl+G toggles grid display
Ctrl+H toggles Pickstyle (group and hatch selection)
Ctrl+Shift+H toggles Palettes display (2009+)
Ctrl+I toggles coordinate display (2009+)
Ctrl+J repeats the last command (Enter)
Ctrl+K displays the Hyperlink dialog
Ctrl+L toggles Ortho mode
Ctrl+Shift+L adds previously selected objects (2013+)
Ctrl+N starts new drawing
Ctrl+O opens a drawing
Ctrl+P print a drawing
Ctrl+Shift+P toggles Quick Properties display (2009+)
Ctrl+Q quits AutoCAD (2004+)
Ctrl+R switches to the next viewport
Ctrl+S saves drawing
Ctrl+Shift+S saves drawing as (2004+)
Ctrl+T toggles the Tablet mode
Ctrl+U switches polar tracing
Ctrl+V pastes the Clipboard contents
Ctrl+Shift+V pastes contents as block
Ctrl+W toggles object tracing
Ctrl+X cuts contents to the Clipboard
Ctrl+Y redoes the undone action
Ctrl+Z undoes the last action
Ctrl+PgDn switches to the next layout (2004+)
Ctrl+PgUp switches to the previous layout (2004+)
Ctrl+Home switches to the start tab (2016+)
Alt+F8 VBA macros
Alt+F11 VBA editor
temporary override keys (2006+):
Shift switches ortho mode
Shift+- switches dynamic UCS mode (2007+)
Shift+) switches object tracing mode (2007+)
Shift+. switches polar mode
Shift+A switches osnaps
Shift+E switches endpoint osnap
Shift+C switches center osnap
Shift+D disables osnaps and tracing
Shift+M switches middle osnap
Shift+Q switches object tracing osnap
Shift+S enables osnap override
Shift+W starts SteeringWheel (A2009+, fixed)
Shift+X switches polar tracing
Shift+F1 subselection mode (all/off)
Shift+F2 subselection mode (vertices)
Shift+F3 subselection mode (edges)
Shift+F4 subselection mode (faces)
Shift+F5 subselection mode (history in compound objects)
CTRL+mouse cycles selection of overlapping objects (till 2006)
Shift+space cycles selection of overlapping objects in 2D (2007+)
CTRL+space cycles selection of overlapping sub-objects in 3D (2007+)
CTRL+ALT extrudes the selected region into 3D - PRESSPULL (2007-2009)
CTRL+arrow moves cursor
Arrow up/down - command history
CTRL+SHIFT+letter goes to the property in the Properties window
ALT+down arrow opens a list in the Properties window
ALT+up arrow closes a list in the Properties window
Of course all the Windows shortcut keys remain active as well (Ctrl+Tab, Ctrl+F3, Ctrl+F6 etc.). Other shortcuts may be defined as user keys in the ACCELERATORS section of your AutoCAD menu. Since AutoCAD version 2006 you can also use CUI to define so called temporary override keys.
ACADLTADTMapMDT
3.2.2008    149157×   FAQ
Prices - CAD eShop:
Tip 12117:The Ctrl+Shift+letter hotkeys do not work (e.g. Ctrl+Shift+C in AutoCAD)
Tip 11721:A handy calculator - expression evaluator in 3ds Max.
Tip 11523:How to reset default dialog positions and sizes in Fusion 360?
Tip 10299:Hide AutoCAD drawing objects with Ctrl+Alt+H.
Tip 10222:How to add keyboard pan (shift view) to AutoCAD?
