Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 12833:
Question
Even in Fusion 360 you can use colour hues from the German RAL color library (paints, industrial enamels). Just download the .adsklib material library for Autodesk products (incl. Fusion 360) - see DL Download
After unzipping, load this palette in the dialog "Material browser" (3D MODEL > EDIT > Manage materials, bottom left icon, Open). In the material tree, choose RAL_Colors, switch to the Appearance tab and add the given RAL color to Favorites by right-clicking on it. In the Appearance Library then apply the requested appearance (RAL color) just by dragging it to your 3D model.
You can also extend your Fusion 360 to use RAL, BS (British Standard BS381C, BS2660 and BS4600), AS (Australian Standard AS2700), AMS 595A (Aerospace Material Specification), DIN 6164 or NCS (Natural Colour System) Color Libraries in Appearances by downloading the RALcolours ZIP file from DL Download, unzipping it to the C:\Users\[username]\AppData\Local\Autodesk\Common\Material Library\20081401\slib\resource\PantoneColors folder and restarting Fusion:
RAL Colours
See also the Tip 11831
Fusion360
1.1.2021    28627×
Share the tip:
applies to: Fusion 360 360 ·
Tip 13900:How to convert truecolor color hue to the nearest AutoCAD ACI color?
Tip 13822:Fast layer visibility toggle ON/OFF.
Tip 13706:Visual style Sketchy with colored edges.
Tip 13597:How to convert RGB color to Pantone, RAL, AutoCAD ACI, CMYK or vice versa?
Tip 13590:How to set the hatch background color?
Back    All CAD Tips
Categ:
VRMLout More info
