  Visitors: 6270
CAD tip CAD tip # 9706:
Where to set the number of decimal places for Robot output tables?
A - answer On the Tools tab in Robot Structural Analysis, click on the item Units and Formats...:
In the dialog then expand the option „Units and formats“. In the individual branches divided by categories (Dimensions, Forces, Unit Edition, Other) you can set the requested display format for the given value. You can choose rounding for a number of decimal places (using the left/right arrows), set the display format, change physical units, etc.
These settings can be then saved as a tepmplate, or you can store multiple templates and switch among them as required.
Robot
24.2.2014    6427×
Prices - CAD eShop:
Tip 11634:Which CAD/BIM products are supported by the visual programming tool Dynamo?
Tip 10923:Which Autodesk products do support the IFC format?
Tip 9333:Which CAD and BIM formats are supported in Autodesk Robot Structural Analysis 360?
